K20Z4 Base Map
Crx_AA
K20Z4 Base Map
Post by Crx_AA »
Hello,
Recenty i swap my crx with k20z4 install Kpro v2 and need a base map to tune a car. Car run's great but vtec dont open. Now i'm running k20a2 base map
BumbleWood
Re: K20Z4 Base Map
Post by BumbleWood »
Not sure if I'm allowed to share a map but this is a basic Fn2 (k20z4)map the only mod is a gruppe m induction change.It was done by a really good uk based tuner and tested on a notoriously tight Dyno and made 195hp and the car drives lovely in the middle gears loads of 3rd and 4th gear pull between 45 and 85 mph B Road driving is a real laugh.
Hope it helps.
typer86
Re: K20Z4 Base Map
Post by typer86 »
Iam not sure if kpro working with the RSP based ECU.
If you are using the K20a ECU check the wires and sensors, groundings etc.
Br
