R18 new air intake system
Kevin1166
Post by Kevin1166 »
Hello
R18 engine Hondata flashpro manager.
I have changed Air intake system From K&N SRI (pipe2.5"Mass flow) to New Air intake system (pipe3"Mass flow)
What values ​​do I need to adjust? To accommodate this change
thankyou
Re: R18 new air intake system
The AFM Flow table until your fuel trims are close to 0.
Kevin1166
Post by Kevin1166 »
Thank you for your suggestion
Civic R18 Calibrations
Can you explain the adjustment in the window ignition retard gear compensation
if I increase or decrease what will happen to fuel and ignition?
You should leave that adjustment alone until after all other tuning is done. In most cases that should never be changed.
Kevin1166
Post by Kevin1166 »
Spunkster wrote: Thu Sep 05, 2019 9:46 am You should leave that adjustment alone until after all other tuning is done. In most cases that should never be changed.
I will follow your instruction
thank you
