Tc. Retard without real slip
k20brasil
Post by k20brasil »
Hello, see if you can help me, I have TC. Retard (small pulses of retard) as if they were interferences, even without real slip with car in low charge.
We always install in the same way (as manual) Grouds and etc, but I have these small pulses of TC retards and in the launch I have enough TC retard.
Thank you.
low boost litle tc retard pulses.fpdl
tc rertard in low.fpdl
Re: Tc. Retard without real slip
What are you traction control settings? Seems like your target is low and the slip to retard table high.
You need to take a datalog with both USBs connected so that we can see all the data from the traction control.
k20brasil
Post by k20brasil »
2 usb logs
In these logs occurred in rare moments, but occurred at the time of launch control
2 SB LOG.fpdl
2 SB LOG.2.fpdl
You appear to have the wheel speed sensors wired to the wrong wheels as it is showing that the right front and Left rear are both spinning much faster than the other 2 wheels.
k20brasil
Post by k20brasil »
What I am finding wrong is that are "pulse peaks " is not constant the wrong reading, see in the photos even in the vacuum phase in the collector without having as spining, we have a peak speed reading absurd and then returns to normal.
k20brasil
Post by k20brasil »
On the first Picture (488mph) car is stop and in launch control. but car is stop.
What sort of vehicle is this? Have you got the traction control box set for inductive or constant current wheel speed sensors?
