p0140 error
takumiwannabe
p0140 error
Post by takumiwannabe »
I installed 2 weeks ago, and I had my ecu unlocked
Here is my setting in flashpro
Under close loop parameters,
I unchecked all of them except split injection enabled
Under modifications
BOOST (REMOVE FACTORY BOOST)
EXHAUST (DISABLE 2NDARY O2 SENSOR FOR DP)
FUEL (0% ETHANOL)
SENSOR (REMOVE P0101 & P0103 ERROR)
THROTTLE (IMPROVE RESPONSE)
TRACTION (TRACTION CONTROL AGGRESSIVE LAUNCH)
TURBO (INCREASED TURBO CHARGER BOOST LIMIT)
TURBO (INCREASED TURBO CHARGER PRESSURE RATIO)
After reflashing my ECU, I still get p0140, is there a fix for this?
Also, I need to reconnect my flashpro everytime before I start the car in order to let it connect with my Hondata Mobile app, so I can clear the cel through the APP, is this normal?
Thanks in advance!
Re: p0140 error
What ECU do you have?
We added the P0141 to the last release for the FK2, so it might be worth updating your software and reflashing.
takumiwannabe
Re: p0140 error
Hondata wrote: Fri Sep 06, 2019 3:56 pm What ECU do you have?
My car is a 2017 FK8
I just updated flashpro manager to the newest release 3.4.4 and reflashed the ECU, still getting a p0140 code...
Re: p0140 error
Ok, let's start at the beginning then. What vehicle, what ECU and what calibration do you have? Posting the calibration here would help.
4BANGER
Re: p0140 error
Post by 4BANGER »
@Hondata, yesterday i purchased your FlashPro and Instant jailbreak, also installed PRL decatted exhaust. Uploaded the attached tune, while driving home CEL P0140 and p0136 came on, i disabled the 2nd O2 sensor from the mods settings and did not reinstalled the O2 sensor on the exhaust Since its been disabled. Should i have reinstalled it even though its disabled? Any help would be appreciated. Thank you
Re: p0140 error
If the so2 is not even plugged in then you will have to disable those error codes.
Tunanocrust13
Re: p0140 error
Post by Tunanocrust13 »
Yes I would like to know more on this I'm having the exact same issues with a catted PRL Dp and I'm throwing a P0140 code how do I delete that with hondata?
Re: p0140 error
You should not get that error with a cat, so check the o2 sensor is plugged in and the wire are not broken.
Otherwise look under Misc DTCs in the calibration, but like I said you should not get that error.
Masterkiro
Re: p0140 error
Post by Masterkiro »
Hi just installed a prl dp & AWE exhaust and am now throwing P0136 & P0140 even after I refreshed with the hondata update from Oct 3. I've unchecked all of the boxes in closed loop except split injection & the bottom codes for fuel enrich, any help would be great cause this is throwing a cel & rev match. Also I do have my secondary o2 installed still if that matters
Masterkiro
Re: p0140 error
How? When I reflashed my ecu I disabled my secondary o2 and have now unchecked every box in closed loop except split injections at the top and am still throwing codes, unsure what else to disable?
Re: p0140 error
