Flashing CEL, no dataloging
akis
Post by akis »
I installed a hondata s300 v3 in the ecu P30-G00 flashes CEL and does not datalog. It also has a 4,000 rpm limiter
Re: Flashing CEL, no dataloging
Is J12 cut?
akis
Post by akis »
yes i have cut it
Post pictures of the bottom of the ECU showing the soldering that has been done.
akis
Post by akis »
These are glues but now I have peeled off one edge of j1 to work stock
akis
Post by akis »
notice that my brain has resistance to the r52 position that no other p30
It looks like there may be a few bad solder joints on the 28 pin connector.
akis
Post by akis »
I measured all the lines one by one with the multimeter and it was OK. Yet I stuck it again and does exactly the same. The red light also flashes.
I would recommend retouching all the joints with some solder and the soldering iron and see if that has any effect.
akis
Post by akis »
I've tried it
akis
Post by akis »
I notice that the red light dim flashes. Either I have it in the ECU or I have it connected to the computer alone.
I would recommend that you try the s300 in a known working ECU from another vehicle or a friend and see if it works properly then.
akis
Post by akis »
It is difficult but I will look for it. The problem is that I bought it new and it never worked.
Everything is tested here before they are sold, so it is most likely that it is an ECU issue. Keep in mind that these ECUs are well over 25 years old now.
