TPedal maximum 96%
Civic 2016+ 1.5 Turbo
turboroe
TPedal maximum 96%
Post by turboroe »
Hi mates, I just started with flashpro (Brazil 1.5 touring version) and I am wondering if TPedal never rising above 96% when flooring is normal.
TPlate goes 101% and I get almost 21PSI boost, and the power is definetely there...
Re: TPedal maximum 96%
If the throttle plate is opening fully, then it does not matter.
Emount91
Post by Emount91 »
my t.pedal only makes it to 96% as well, but t.plate opens 100-101%. so it's as throttled as it can be at 96%.
Emount91
Post by Emount91 »
Here's a datalog that shows t.pedal is at 96% while t.plate is at 101%. Seems normal.
TPEDALdata.fpdl
Hondata, anyway to change the throttle pedal to plate ratio? "improve throttle response" seems too sensitive, while having this mod disabled seems to make the pedal too fluffy. would love an in-between setting or a way to create a custom one.
I think this was doable on the older gens?
