Stock B.O.V.
Civic 2016+ 1.5 Turbo
Joshcornkid
Stock B.O.V.
Post by Joshcornkid »
Is the stock Blow Off Valve adequate for the +6psi tune?
If not, what then is an acceptable upgrade? I can only find 2 direct bolt-on's available.
- The Boomba is an atmospheric vent, which isn't suggested.
- The only other option I can find is the TurboXS, which says it's a Hybrid recirculating some back into the Turbo and some to the atmosphere.
+ https://www.carid.com/2017-honda-civic- ... NGINE|1.5L
+ Does anyone have any experience with the TurboXS B.O.V?
Re: Stock B.O.V.
There's no good reason to replace the factory BOV. People only do it for the noise.
Joshcornkid
Re: Stock B.O.V.
Is it possible to hear the stock BOV? I think I'm hearing it even at full throttle. If it is was defective would I have a CEL?
Re: Stock B.O.V.
If there are no errors then there is probably not any issue.
