Air Conditioning During Acceleration
web35
Post by web35 »
In order to get maximum available power during acceleration, it seems that the AC compressor should turn off during acceleration. Is this programmed into the stock ECU? If so, what parameters trigger this and what parameters turn it back on?
This would be a nice feature to add to the FlashPro so that a user could use throttle position or other variables to turn the compressor off or on. I've done this on older cars with a limit switch and throttle position in series with the power to the AC clutch. With drive by wire it's not so easy.
