Bug/Glitch in 2.7.3 - tip-in retard conditions
crluver123
Post by crluver123 »
I don't know if this occurs in older versions, but since updating to 2.7.3 I noticed an issue with the Throttle tip-in retard conditions. When adjusting vehicle speed minimum and maximum, the values can be changed. But as soon as I save the calibration or change tabs and go back to the tps ign tab, the values immediately revert back to 6mph and 87mph. Fourth and fifth gears, and sometimes third gear, are over 87mph, so I obviously want tip-in retard to be functional above 87mph.
Please advise.
Re: Bug/Glitch in 2.7.3 - tip-in retard conditions
Thank you for the report. This has been fixed. We are releasing a beta version today and the fix will be in that.
crluver123
Excellent, thank you :)
