Rev limiter not working
domesticdc5
Post by domesticdc5 »
Hello, I have the kpro v4 for my rsx type s.
The issue I am dealing with is the rev limiter not working properly, and what I mean is if I set it to the stock 8600 rpm, ill still be able to go past it. This is a big problem, so I though maybe changing it would fix the issue; and surprisingly setting the rev limiter at 4000 rpm worked without an issue. This proved that the rev limiter is indeed doing its job in limiting my revs, so I am confused as to why it doesn't work when I set it to 8600 rpm.
Any advice/tips would be great, this is my first time dipping my toes into the tuning world.
fonzeka
Re: Rev limiter not working
Post by fonzeka »
Are you looking at the dash or in a log?
The dash can sometimes be a bit off, especially in the higher rpm's.
Post a datalog showing this issue along with the calibration use to make the datalog.
