Possible ECU damaged
jdouille
Post by jdouille »
Hey
I allow myself to contact you because I made a error with the wiring battery when i change for Odyssey Pc680.
Well, i have reversed the battery / fuse box alt and bat pin.
Fuse box ATL pin on positive battery cosse and
Fuse box BAT pin on ALT winring.
Car crancking no problem, kmanager with pc ok, map ok all fuses and relay ok, immobilizer ok..... !!!!!
Honda civic type R ep3
PRA ecu Hondata kpro V4
OEM fuse box
I have ride the car maybe 300km before see that error, today I want to know if the ecu can possible be damaged ?
best regards, thanks a lot
Re: Possible ECU damaged
I do not think it matters if the ALT and BAT is reversed. The ELD would not read currently currectly.
jdouille
Post by jdouille »
On Kmanager ELD Reading correctly and sensor are correct
jdouille
Post by jdouille »
jdouille wrote: Sun Oct 06, 2019 1:51 am On Kmanager ELD Reading correctly and sensor are correct
But i have juste thé fuel Relay, blue, is very hot but not all Time, this us relation ?
What error are you getting?
jdouille
Post by jdouille »
I have not Cell or error on Kmanager.
But sometimes she walks hard and other days worse.
Im going to visit my tuner maybe last month.
