Issues with kmanager options
muffpunter
Post by muffpunter »
I'm new to the forum, and have a few questions. I just finished a 92 integra gsr with a k20/k24 swap, rsx type s engine harness, type s ecu with kpro v4. For whatever reason, it seems disabling the multiplexer, ELD, and secondary o2 sensor options seem to have no effect. I still get codes P1298, P0600, P0141 (Keep in mind, the 92 integras do NOT have ELD). I just got the exhaust bolted up today and attempted to drive the car but it runs horribly. Another issue is that the map sensor may be bad as the readings were not changing on the kpro app. I will be replacing the map tomorrow though.
While researching, I saw people mentioning "disabling OBDII" or "enable emissions error checking" options but that may have been on an outdated version
any insight would be appreciated
muffpunter
Re: Issues with kmanager options
Here's some more info...
muffpunter
ecu 37820-PRB-A03
Not sure why pic is upside down
muffpunter
I replaced the MAP sensor today, but it didn't help with how bad the car is running. It seems like storing the calibration has no effect on the ecu, even though retrieving the calibration is identical to the one uploaded.
muffpunter
why do these errors keep coming up? I must be missing something here.
Have you uploaded the calibration to the ECU once you made the changes?
