About modification screen
gcapraz
Post by gcapraz »
Hi Everyone. I m the new user of hondata.
I bought second hand flashpro for my car which is 2018 civic hb 37820 5AN G82 ecu number from turkey but it's made in UK.
In your website it says has support. I installed it but modification screen is fully empty. My car has dp-fp and I need to close o2 sensor as you know and also need to check it some others.
For my ecu, do I have fully supported ecu or semi supported ecu.
Re: About modification screen
Reinstall the software and make sure you select ALL models when installing it.
gcapraz
Post by gcapraz »
Spunkster wrote: Mon Oct 07, 2019 10:45 am Reinstall the software and make sure you select ALL models when installing it.
I uninstall the software and reinstall it again then select all models but there is no mods list on 1.5t G82 UK made tunes.
Can someone check it with Hondata software?
Our software engineers have corrected the issue for the next release.
