No analog input values
cseanard
Post by cseanard »
I cannot get the data logging sensors to read the 0-5v analog inputs.
I set it up correctly in the analog input tab and tested the voltage at the analog input header.
Any suggestions?
I have read multiple tech and wiring pages.
http://www.hondata.com/help/smanager/in ... meters.htm
Re: No analog input values
Post your calibration as well as a datalog showing the issue.
cseanard
Post by cseanard »
Thanks for responding.
I can see values for them in the datalog. Make sure that you have a template set up that has the analog inputs setup to display and you should then see them in the graph window.
cseanard
Post by cseanard »
I see it now on the sensors section, I must have something setup incorrectly on the display sections.
You have selected the ECU analog inputs, and not the AN1 and AN2 analog inputs from the s300.
DaX
Post by DaX »
cseanard wrote: Tue Oct 08, 2019 9:59 am Thanks for responding.
Are you in Chattanooga? Based on the title of your log, I'm guessing so.
