Ef k24 vss signal issue
Mgerrow
Post by Mgerrow »
1990 civic dx
k24a2, 02 rsx s transmission
02 rsx s harness
02 rsx s speed sensor
rywire chassis conversion harness
Version 4.4.2.0 manager
ppa ecu from humble
Vehicle registers speed on cluster, but nothing on display in kmanager. Tested circuits, reloaded multiple maps with normal speed sensor selected. Loaded k20a2 map, edited map. no vss speed registers in kmanager. Any help would be appreciated.
90 hatch k20a poormans build z3 gear swap
Re: Ef k24 vss signal issue
Post your calibration as well as a datalog showing the issue.
Mgerrow
Post by Mgerrow »
10-4
Mgerrow
Post by Mgerrow »
Log and calibration, sorry for the delay had pc issues
SN:50264
It looks like this was an install kit sold to Humble so you should contact them about this as it could be an ECU issue and they should be able to help you get another ECU and swap the K-Pro into it if it is in fact the ECU that is damaged.
Mgerrow
Post by Mgerrow »
Ecu fixed the Issue. sorry for the delay in response and thank you for the help. Another ef is giving my issues now, this time its my car go figure. posted about it.
