97ek b18b1 turbo swap Hondata won’t light up
97ekboostman
Post by 97ekboostman »
I have a 97 EK coupe I finished it about five months ago be 18 B1 swap I’m running a Hondata s300 v3 p28 I recently was in a small fender bender my turbo snapped in half but that was the only damage to the vehicle aside for my passenger airbag going off and the front radiator support got bent. Everything was replaced I finally have it all back together prime the new turbo my motor cranks over but won’t start I noticed my Hondata Use the light up when I turn the ignition on but now it doesn’t only my gauges on my dash do. Any thoughts?
97ekboostman
Re: 97ek b18b1 turbo swap Hondata won’t light up
Also I don’t think that it matters but the passenger airbag is unplugged don’t know if it sends it into a limp or safety mode because the airbag went off?
You should try the ECU in a known working vehicle and that will tell you if the problem is related to the vehicle or the ECU and point you in the correct direction to continue troubleshooting.
