‘19 CRV map Q
CRV 2017+ 1.5 turbo
Davesxx01
‘19 CRV map Q
Post by Davesxx01 »
I’ve confirmed my ECU is supported (5PA-653) and just wondering exactly how many maps are available for me to choose from. (Race, not CARB)
Also, can I change boost, turbo response, ECO mode. Etc.
any way to post a pic of the map choices?
Re: ‘19 CRV map Q
You can download the software and install it then go to New calibration and select your vehicle and then you can see all the available calibrations.
Davesxx01
Re: ‘19 CRV map Q
Post by Davesxx01 »
Thanks! I see 3 maps available. +6, CARB +6, and ECO +6.
I don't see any adjustment tables for optimized throttle or boost. Do they show up after I register my flashpro or are they not available?
Also, is the ECO +6 the map that when ECO is activated the vehicle returns back to stock boost/operation?
Re: ‘19 CRV map Q
There are no mods for the CRV. All other changes are made in the calibration window. If the Calibration with ECO mode is used, then when ECO is turn on, the engine makes factory boost levels.
