Help - Smanager stops datalogging TC wheels speeds after some time
carnot
Post by carnot »
I am experiencing and issue where Smanager stops datalogging wheel speeds after about 8-10 min of driving. TC is still working but the actual wheel speeds stop being datalogged. Thank you in advance.
Re: Help - Smanager stops datalogging TC wheels speeds after some time
What wheel speed sensors are you using?
carnot
Post by carnot »
Stock inductive wheel speed sensors that came with my 1995 Honda Prelude.
Does it always stop after about the same amount of time?
carnot
Post by carnot »
No, sometimes I can drive around for 30 mins or so with no interruptions in datalogging. However, if it does have a problem it seems to happen around the 8-10 min mark in datalogging.
carnot
Post by carnot »
Looks like 2.7.3.0
Download the latest beta version and see if that resolves the issue: http://www.hondata.com/forum/viewtopic.php?f=19&t=22629
carnot
Post by carnot »
I tried the new beta version but still having the same issue as you can see in the attached datalog. Datalogging of the wheel speed sensors is going along fine until about the 6:45 mark and then it just stops.
If you unplug the USB from the traction control and plug it back in does it show the wheel speed in live data?
Please try this version
carnot
Post by carnot »
I tried the new version of Smanager and it still stopped logging around the 12:30 mark in the attached datalog. Is it possible it is something with my laptop or windows settings?
Are you using resistor or non-resistor type spark plugs?
carnot
Post by carnot »
I believe they are resistor type, NGK NKR7Es
Is the screen going to sleep when this happens?
