Lambda very lean at WOT!
R-12914
Post by R-12914 »
Hi Hondata,
since a few days abruptly without having made changes anything, my WOT Lambda is only very lean at 0.85-0.86.
Before it was on 0.80-0.81.
I have send you Logs and Maps via Email.
What is the problem or could be the problem?
Thank you!
BTW: Maps & Datalogs i have send you via E-Mail
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Re: Lambda very lean at WOT!
I don't really see a drastic difference in them. Where exactly in these are you seeing an issue?
R-12914
Post by R-12914 »
In WOT it should be Lambda 0.80-0.81 on my supercharged engine.
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
Spunkster wrote: Tue Nov 19, 2019 2:43 pm I don't really see a drastic difference in them. Where exactly in these are you seeing an issue?
Please look on the "2.35_18-11-2019" Datalog on 14:12 minutes for example.
Thanks!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
curtusz wrote: Wed Nov 20, 2019 3:36 am Could be injector oring seals, happened to mine (not supercharged)
Do you have a datalog from this?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
