? with e85 tuning
Civic 2016+ 1.5 Turbo
weebz69
? with e85 tuning
Post by weebz69 »
So I have e54 here in arizona. so I was wondering does the car have like an ethanol sensor on it? or is that something you have to buy. I see in the tune it has something like if it reads this or that "ethonal" it advances timing another 2 degrees. My question is that flex fuel tune is mostly likely setup for e85. What happens if I just threw e54 in it and ran that tune until I could have a local tuner dial her in? Anyone else try this in arizona?
Re: ? with e85 tuning
You must install a flex fuel kit in order to use this and it allows you to use any mixture of ethanol. You should not just dump in E54 and run untuned without a flex fuel sensor and being properly set up.
weebz69
Post by weebz69 »
Awesome thanks man
turboroe
Post by turboroe »
Can someone recommend a good flex fuel kit and where to purchase?
weebz69
Post by weebz69 »
https://www.procivic.com/index.php?rese ... ts_id=3166
I used this kit, it's easy to install along with hondata flex fuel tune, my god I probably picked up 50ftlbs
