K24A2 crank no start
ChrisKDC4
Post by ChrisKDC4 »
Hello
I have an 97 Integra DC4 with a 06 TSX swap with matching trans.. Vehicle was running fine with accord tb.. Recently changed out the accord t/b to a aftermarket RSX Drive by wire (skunk 2 to be exact) with a Aquity TPS... with IAVC delete.. Now that i changed over to this set up, and made
appropriate changes to the calibrations, vehicle now cranks and no start.. would like input on data log.. THANKS!! :)
Setup: K24a2 w K24a2 Trans, 70MM skunk2 tb, Karcepts adaptor plate, Acuity TPS, PLM Header, Custom 3' Exhaust to vibrant 3' Muffler
ChrisKDC4
Re: K24A2 crank no start
Post by ChrisKDC4 »
note: Just noticed O2 sensor voltage in that datalog to be 0v...
ChrisKDC4
Post by ChrisKDC4 »
ChrisKDC4 wrote: Fri Nov 22, 2019 12:15 am Hello
Also note: kpro serial 50601
verision 4.4.2.0
ECU 37820-ppa-a03
MAP sensor is reading full voltage so you're on a boost cut.
