S300 intermittent issue
Tylenol21798
Post by Tylenol21798 »
Blips in ecu car will read fine, but blips randomly and shows the ecu going crazy. I've attached a picture of what it does when It blips
Tylenol21798
Re: S300 intermittent issue
Here is my map and datalog
crluver123
Post by crluver123 »
Check the ecu grounds in the engine harness, and any other grounds you can find.
Make sure you are using Resister spark plugs (R in the plug part number, like BKR7E).
If you have a jumper harness, it may be of bad quality and have a bad wire somewhere.
Post a picture of the bottom of the ECU showing the solder joints for the ECU socketing.
Tylenol21798
It's done with rosin core solder
Tylenol21798
I'm thinking it may be a bad wire in the jumper harness, I discovered if you more the ecu the car almost dies.
That sounds very likely.
Tylenol21798
I'm getting a new one this week. I'll update you if it fixes the issue
Tylenol21798
The jumper harness has seemed to fix the issue. Thank you guys for the help.
