Intermittent red light when start
jdouille
Post by jdouille »
Hello everyone.
Honda civic type R ep3 eudm pra ecu 2002.
Hondata kpro v4, bolts with perfect Map on dyno. 242ch and 231nm
When i started my car i have a green light but when turn the Key for ckanking engine my Ecu light red for little moment and return green.
It's normal ? Because the car it's verry slow and loss power on the road.
It's an intermittent problèmes !!! No change parts on car and the Map it's perfect.
Re: Intermittent red light when start
Are you able to datalog? Are there any errors?
jdouille
Post by jdouille »
My tuner doesn't explication, no cell, ,no error.
On Datalog there are not visible problems. I have a battery Odyssey PC680 and the exterior temperature around 5C°
But starting is not dificulte.
Battery it's possible cause ? two years old and complet charge with CTEK it's ok.... or Kpro card failed ?
It sounds like you may be getting a daughterboard communication error from low voltage when cranking.
jdouille
Post by jdouille »
When the first step "contact Key" engine off.
The light is red then green on Kpro. It's normaly ?
It's not green all Time before start engine.
You should use a multimeter at the ECU to check the voltage when cranking.
jdouille
Post by jdouille »
Ok.
What this Pin for read a multimeter ?
A2+ and A4-
