KManager Datalog Table Issue
DC5teggi
Post by DC5teggi »
On the latest available update (4.4.2), when viewing a datalog, the tables are no longer automatically updating to represent the cam angle used. Is this a known issue?
To clarify, if I am viewing the 50 cam angle fueling table and press play on the datalog, it no longer jumps to the appropriate cam angle. It will automatically jump to the high or low speed tables properly, though.
I believe this issue is universal, but just in case, below are my specs:
- Vehicle: 2003 Acura RSX Base
- K-Pro Serial Number: 47443
- KManager Version: 4.4.2.0
- ECU part number/serial number: 37820-PND-A03 / 2062-200505
2003 Acura RSX - K20A3
PND ECU with K-Pro v4
Re: KManager Datalog Table Issue
Post your calibration and a datalog showing the issue.
DC5teggi
Post by DC5teggi »
It doesn't matter what calibration file or datalog I'm using. I've tried multiple (including stock calibrations) - it's a KManager related issue. The issue was not present before I updated to 4.4.2 - the tables would automatically jump to the appropriate cam angle for that point in the datalog.
I've attached the files anyways, though.
The datalog you have provided is working as it should. Make sure you go to the Options menu and that tables follow Cam Angle and tables follow VTEC are checked.
DC5teggi
Post by DC5teggi »
Hah. I was hoping it was something that simple. Somehow that option got turned off during the update then, since I never activated it. Thanks!
