Hesitation when VTEC engages
boofman11
Post by boofman11 »
Have P28 with S300, JDM b18C wiseco 9:1 pistons, eagle rods, precision 5831e, log manifold, 2.5" dp and exhaust, tial f38 with 11lb spring connected to vacuum manifold direct, id1000s, M&W pro 10 with crane 92n coil gapped BKR8EIX at 0.27"
. Was running E85 and switched back to 91 and there is a pretty bad hesitation around 4500-5000rpms, sometimes it can make it to 5300rpms.
I tried moving the VTEC engagement point and it did not seem to affect this issue. I am aware its very rich when boosting and i keep lowering the fuel in those cells little by little, but seems like the issue has not changed.
Any help you could provide would be much appreciated.
willie4x4
Re: Hesitation when VTEC engages
Post by willie4x4 »
iam having the same problem does yours only do it for a few seconds then rev fine
boofman11
Post by boofman11 »
I just let off gas when it happends. Seemed better when i had the 16psi spring in, now i have the 11psi spring. Its right when VTEC kicks in it just jumps in and out of VTEC hesistating.
willie4x4
Post by willie4x4 »
Your tps doesn’t look like it is working
boofman11
Post by boofman11 »
I just checked that graph i see what you are saying, i think when the hesitation happens i let off the gas completely maybe. I just checked the range it seems smooth, wonder if it could be it getting warm though? weird
boofman11
Post by boofman11 »
Ill try a spare one i have, the one installed on there is aftermarket and unknown brand or age.
boofman11
Post by boofman11 »
Changed TPS out with another, verified calibration. Same hesitation. Bummer..
Your air fuel is richer than 10:1 in places. That is the problem.
boofman11
Post by boofman11 »
Hondata wrote: Fri Dec 27, 2019 12:51 pm Your air fuel is richer than 10:1 in places. That is the problem.
You were right, had to end up taking 17% out of all secondary fuelmap.
