Cut signal for flat shift
Paulwalsh2252900
Post by Paulwalsh2252900 »
Hi, I have a cut signal which is (pulled up to 5v,pulls to ground for duration of cut) was wondering if E16 or E29 can take the 5v ?
Re: Cut signal for flat shift
Yes, 5V or 12V will not harm those inputs. I would check that 5V is enough to switch off the input though.
Paulwalsh2252900
Hi thanks it seems to be working just fine.
jj portworx
Post by jj portworx »
can you do share how you did it? wiring, etc..
