Kpro Tip in fuel issue
h2.4
Post by h2.4 »
Hello, I was wondering when I have my tune open in Kmanager, the Tip in fuel tabs are available and I can make changes on my laptop, Upload the tune file. But when I have the it plugged into the car, the tip in fuel options are not accessible. I need to have access to the warmup tip in enrichment and general Tps tip in to get it right with these injectors.
I have an early Kpro board, serial # is 05002865 Pnf ecu running K24a2
h2.4
Re: Kpro Tip in fuel issue
Post by h2.4 »
So I think I might have found what the problem is. I am using a Pnf ecm with a Pnf base tune but have Prb tables copied over to the Pnf startup map. So the Tps tip in is viewable in the Prb kal when on laptop, but tune in car is built off of a Pnf kal with the Prb tables copied over. So I will build a new Kal file purely from the Prb and try to flash that over onto the Pnf ecu, I'm sure it's ok to flash the Prb kal file onto the Pnf ecu with no problems?
h2.4
Post by h2.4 »
Ok, well I redid a Prb kal and flashed onto Pnf ecu. Still no Tps tip in tables when connected to the ecu. So does this mean that the Pnf ecu doesn't support Tps tip in? Or am I doing something wrong? Hopefully I don't need to run a Prb ecu to have all the Prb tables available..?
These are only available with the KPro4.
h2.4
Post by h2.4 »
Hmm. Ok. That's a bummer, it seems tip in fuel is a pretty basic necessity. Weird that it's not available unless I upgrade. Thanks for clearing it up.
