2019 Calibrations for 2019 Civic 1.5 CVT Indonesia
arnoldod
Post by arnoldod »
Hi Hondata Team,
I cannot find basemap calibrations for 2019 Civic 1.5 CVT Indonesia in Flashpro International version that I own.
Could you please advise which available calibrations I could use?
My ECU is supported by Flashpro international version.
I'm currently using 2016 Civic 1.5 CVT Thailand.
Please advise.
Thank You
Re: 2019 Calibrations for 2019 Civic 1.5 CVT Indonesia
With it locked to the vehicle and plugged in you should open the software and it will automatically select the correct vehicle type when you click on new Calibration unless your ECU is not yet supported.
arnoldod
Post by arnoldod »
Spunkster wrote: Thu Jan 02, 2020 1:05 pm With it locked to the vehicle and plugged in you should open the software and it will automatically select the correct vehicle type when you click on new Calibration unless your ECU is not yet supported.
Thank you. Apparently the ECU is the same as 2016 Civic 1.5 CVT Thailand.
