s300 registration?
90TegGSR
s300 registration?
Post by 90TegGSR »
I just received my P72 with installed s300.
A lot of people suggested I should get this for the gsr I just swapped into my 90 Intera LS.
However, I'm leaving the engine stock except for a little free flowing intake tube (k&n) and header (dcsports 4-2-1).
So I'm considering, not using it.
If I plug it into my car it loses value on the market.
If I register it, then isn't it associated with me and my car?
The selling it wouldn't be possible at all?
Re: s300 registration?
This is completely up to you and will be between you and the buyer.
crluver123
Post by crluver123 »
plugging it into your car doesn't affect market value
90TegGSR
Post by 90TegGSR »
There's a guy just a few posts away from mine. He bought it from somebody used, and even with the previous owner's password, he can't get in.
90TegGSR
Post by 90TegGSR »
Spunkster wrote: Fri Jan 10, 2020 10:58 am This is completely up to you and will be between you and the buyer.
So even if I do register it, it's transferrable. Just change the contact info?
crluver123
90TegGSR wrote: Fri Jan 10, 2020 4:24 pm There's a guy just a few posts away from mine. He bought it from somebody used, and even with the previous owner's password, he can't get in.
a password is not required. That is an option that has to be manually added
90TegGSR wrote: Sat Jan 11, 2020 9:18 pm So even if I do register it, it's transferrable. Just change the contact info?
Yes
90TegGSR
Post by 90TegGSR »
Looks like I'll keep it. I think the base map that comes in the hondata installation files, will work fine it this almost stock b18c. I just want'a have a car I can dive another 20 years. I'm only putting on 4k miles per year, so it could with good maintenance and maybe a little bit more wiring as time goes on.
I'm just bitchin' about all the money I've had to spend. Quite a bit more then I thought.
