U0301 2016 Civic Touring
Civic 2016+ 1.5 Turbo
murie00
Post by murie00 »
I have a US 2016 Civic Touring. When attempting to flash the CARB 2016 Touring +3psi or +6psi or the CARB 2016-2017 Touring +3psi using Flashpro 3.5.1.0 I get a U0301 code. If I flash back to stock the check engine light goes away. Before attempting the flash I did recently have the "VSA Software Update/EPB" recall fixed.
I know the Canadian version you need to flash the 2017 version due to a recall but that is not an option with the US cars.
Any suggestions would be appreciated! Thank you
*edited because I forgot to say I was trying to do CARB safe
Re: U0301 2016 Civic Touring
If you have the oil dilution update from Honda then you must use a 2017 calibration or you will get a transmission error code. If you use the return to stock then you must use the 17 return to stock as well.
murie00
Post by murie00 »
Thank you for your help!
Since there is no US 2017 Touring CVT can I use one the US 2017 Hatch Sport Touring CVT? I assume I can't flash the Canadian 2017 on a US car.
There is one labeled 2016-2017 touring CVT.
murie00
Post by murie00 »
Correct, there is one that is labeled 2016-2017 touring CVT. However, this is one of the ones that causes a U0301. Any other suggestions?
Then you do not have the update and should use the 2016 calibration.
murie00
Post by murie00 »
Okay, but both the CARB 2016 Touring +3psi or +6psi both give the same check engine light. I have tried to flash all 3 multiple times.
Do you have a CARB FlashPro? If you have had the oil dilution update then you should use the 2017 calibrations unless the dealer made a mistake and did not reflash the transmission.
murie00
Post by murie00 »
I do have the CARB FlashPro. I do not have the oil dilution update (unless it was performed without my knowledge). I have tried both calibrations multiple times.
However, I just thought of the fact that I had this service bulletin applied. "2016-18 Civic 1.5L: Software Update with A/C Control UnitReplacement; DTC P0300, P0301, P0302, P0303, P0304, or P0172" This was released March 5 2019.
I am thinking that maybe there is a software update after the oil dilution that Hondata does not have yet?
Do you get the error if you just upload the 2016 calibration?
murie00
Post by murie00 »
Yes to the 2016 calibration.
Will do on the issue. Thank you for your help!
Igneousbrbp
Post by Igneousbrbp »
I'm getting this same code. I managed to reflash to stock, but I wish to use the +6 and it keeps throwing the u0301. Any thoughts?
Does your vehicle have the oil dilution update form Honda?
