Aem 30-4900 in kpro
miahjera04
Aem 30-4900 in kpro
Post by miahjera04 »
So I'm running the 4900 gauge from aem. It's an afr/boost gauge failsafe. This is NOT in kpro in the drop down options in the closed loop tab. I'm having issues w/kpro reading a different afr then what the gauge is showing. I selected the 4100 option in the drop down bc that's an older bosch style gauge as well... I need help as to what needs to be done so kpro is reading identically to my gauge.thanks
Re: Aem 30-4900 in kpro
You need to compare the voltage conversion info from AEM for both gauges and see if they are the same. It sounds like they are different. AEM has a habit of everyone of their gauges being slightly different than the rest.
