Vtec On non-vtec HONDATA ecu
lozano232323
Post by lozano232323 »
Soo Im building a d16y7 with a z6 head swap and a non vtec obd1 converted harness and I’m trying to figure out how run Vtec with the non-vtec hondata. There’s a option to do that with the S300 but it doesn’t really explain how
MikhailBjornson
Re: Vtec On non-vtec HONDATA ecu
Post by MikhailBjornson »
Scroll down a little bit and it gives u a diagram on how to wire the solenoid if using a non vtec ecu.
https://www.hondata.com/help/smanager/i ... l?vtec.htm
If you can so some soldering and are comfortable with messing with your ecu then depending on the ecu you can actually convert your ecu to run vtec.
lozano232323
MikhailBjornson wrote: Mon Jan 13, 2020 8:33 am Scroll down a little bit and it gives u a diagram on how to wire the solenoid if using a non vtec ecu.
Soo i would use one of the relays from the fuse box that’s in the engine bay?
No, you must use a separate relay that you supply.
