s300 not downloading or uploading
oksdesigns
Post by oksdesigns »
s300 on software is not being able to upload or download map when connected. I can connect/ datalog to s300 (lightning bolt) and download my logs off the ecu, but I cant test my outputs, upload nor download any maps. is this more a wiring issue and if so where should I check first
Re: s300 not downloading or uploading
From Help, About, what is the version of software that you are using?
