Car wont start after Reflash need help
Civic 2016+ 1.5 Turbo
brimac1
Post by brimac1 »
My civic hatchback 1.5 CVT won't start after a reflash, I have reflashed it before and it worked but after testing it out and noticing it fails to change gears I wanted to return it to stock to put it on the +3 psi option.
When I press down on the brake and press the start button it does not start but the dash does light up. I'm not sure if I should keep trying to reflash to stock.
This is the error code I get.
The last Flashpro upload failed.
Failure information : code 0x05 Step 16 Address
0x0FFF00
Explanation: The ECU stopped responding while
reflashing. Check OBDII connector pins
Re: Car wont start after Reflash need help
What is the serial number that is on the FlashPro?
