Mods - Flex Fuel Support
CarloT
Post by CarloT »
Hi,
So when I want to go back to my standard 95 Octane fuel (with 3.25% ethanol as per hondata gauge) - actually it has no ethanol content - do I uncheck in mods "Flex Fuel Support" ?
So I want to have a primary and a secondary calibration. Primary being using only 95 octane fuel and secondary being 25% ethanol mixed with 95 Octane fuel
I do have a flex fuel kit
Re: Mods - Flex Fuel Support
You can only remove the mod if you completely remove and unplug the flex fuel kit and return it to stock. You do not need two different calibrations as you have a flex fuel sensor that detects the amount of ethanol and adjusts as needed.
CarloT
Post by CarloT »
But isn't "flex fuel support" only enabled if you have a custom tune? (Which I dont have)
So basically you only enable "ethanol input enabled"
Correct?
