B18c gsr skunk2 pro2
JekoB18c
Post by JekoB18c »
Need help my car has
410 rdx injector
Skunk2 pro 2 cams
Supertech valve ,spring,retainers
Type r manifold and throttle body
Idle is so rough and rich
Sparkplugs are really black
When i press the gas it will rev up but the rpm will drop till 200 to 400 almost stall.
When warm up idle will be really rough
Please help
Re: B18c gsr skunk2 pro2
Has this been properly tuned on the dyno?
JekoB18c
Post by JekoB18c »
No not yet but i cannot drive my car to the dyno it always dies out ..1 time i tried to drive it and it dies out and it really hard for me to start it
See if your tuner can provide you with a basemap that runs it better, or you may want to consider towing it to the tuner to get properly tuned.
CalibratEd
Post by CalibratEd »
Do you have a wideband on the car? I can help get the car running.
Instagram: calibrated.tuning
JekoB18c
Post by JekoB18c »
I think we found the problem we put the exhaust cam gear on -3 degrees instead of +3 degrees.i hope i dont have bent valve
