Hey guys,
I’ve tried to search and look at the stock calibrations and couldn’t find anything that fits my request. I did see the stock B16A with the Greddy kit, however the kit is an 18G with stock injectors.
My setup goes as followed:
Motor:
Completely stock B16A2
Turbo:
Drag 3 Kit T3/T4 with inter-cooler ect(its for a b16a2)
38MM wastegate (7PSI spring)
Fuel:
440cc saturated injectors
Stock B16A2 fuel pump/rail/FPR
ECU:
S300 (do I need boost mod)
Can anyone provide a tune/ calibration for this setup?
Let me know if you need any more info or if I missed anything.
Thanks,
B16A2 Turbo calibration/ Tune Request (stock motor/ Drag kit)
- CalibratEd
- Contact:
Re: B16A2 Turbo calibration/ Tune Request (stock motor/ Drag kit)
What brand are the injectors? What map sensor are you running? I can help if you can provide data-logs. Does the car have a wideband?Do1313R wrote: Thu Feb 13, 2020 11:33 am Hey guys,
Motor:
Turbo:
Fuel:
ECU:
Thanks,
Instagram: calibrated.tuning
The car doesnt have a wideband yet. Im waiting to install the kit.CalibratEd wrote: Wed Feb 19, 2020 7:36 pmWhat brand are the injectors? What map sensor are you running? I can help if you can provide data-logs. Does the car have a wideband?Do1313R wrote: Thu Feb 13, 2020 11:33 am Hey guys,
Motor:
Turbo:
Fuel:
ECU:
Thanks,
- CalibratEd
- Contact:
Ok more can get done once you have the wideband connected. For now what map sensor are you using and what brand are your injectors?Do1313R wrote: Fri Feb 21, 2020 4:24 pmThe car doesnt have a wideband yet. Im waiting to install the kit.CalibratEd wrote: Wed Feb 19, 2020 7:36 pmWhat brand are the injectors? What map sensor are you running? I can help if you can provide data-logs. Does the car have a wideband?Do1313R wrote: Thu Feb 13, 2020 11:33 am Hey guys,
Motor:
Turbo:
Fuel:
ECU:
Thanks,
PM'dCalibratEd wrote: Sun Feb 23, 2020 9:34 amOk more can get done once you have the wideband connected. For now what map sensor are you using and what brand are your injectors?Do1313R wrote: Fri Feb 21, 2020 4:24 pmThe car doesnt have a wideband yet. Im waiting to install the kit.CalibratEd wrote: Wed Feb 19, 2020 7:36 pm
