B18b forged internals crower 402 cams
nick01
Post by nick01 »
Anyone have a map similar to the setup in the title? I have tried the b20nonvtec403 that’s in the new calibration section with a 30-3000 X-series wideband and just wanna make sure that’s closest I can get. I have adjusted the ELD off and am on d10 for the wideband input but I just want to make sure that would be a good base to start with, or should I just use the stock integra map and tune from there?? Car is forged internals 1000cc inj, Walbro255 and AEM fuel pressure set to 45.. NA at the moment
CalibratEd
Re: B18b forged internals crower 402 cams
Post by CalibratEd »
nick01 wrote: Thu Feb 13, 2020 3:14 pm Anyone have a map similar to the setup in the title? I have tried the b20nonvtec403 that’s in the new calibration section with a 30-3000 X-series wideband and just wanna make sure that’s closest I can get. I have adjusted the ELD off and am on d10 for the wideband input but I just want to make sure that would be a good base to start with, or should I just use the stock integra map and tune from there?? Car is forged internals 1000cc inj, Walbro255 and AEM fuel pressure set to 45.. NA at the moment
I would start with a stock tune that matches the head you are running. I can help if you can provide data-logs.
Instagram: calibrated.tuning
