v4 Fan problem
MatteoHU
v4 Fan problem
Post by MatteoHU »
Hi,
I have an EP3, 2002, K20A2, RRC Intake, plm header, catback etc.
The car is running on kPro v4, and the issue is: both fans running when not neccessary, and it causes low coolant temperatures. If i start a wide-open pull from 2nd gear, when i shift to 4th my coolant temp is near 70Celsius, and the fans are running. I think the ECU thinks im using A/C, but its mechanical parts from the motor bay are deleted.
Whats the solution? Because my programmer can't establish a good map with changing coolant temperatures over the session..
Re: v4 Fan problem
Post your calibration and a datalog showing the issue.
MatteoHU
Re: v4 Fan problem
Post by MatteoHU »
Spunkster wrote: Fri Feb 21, 2020 5:30 pm Post your calibration and a datalog showing the issue.
Im just a user, i have the guy 300km away, who did the calibration. I can datalog with the bluetooth app only i guess.
Re: v4 Fan problem
You can use the KManager software and a laptop to datalog.
