MAF 2011-2014 TSX
antisocial
MAF 2011-2014 TSX
Post by antisocial »
I would like to disable my MAF for my 2014 TSX, and use only a 2 wire IAT in my supercharger manifold in order to properly monitor IAT. I see this is an option for the 09-10, but not for the 11-14. Can we please make it happen?
EFICU
Re: MAF 2011-2014 TSX
Post by EFICU »
I haven't worked with any Gen 2 TSX's, but there is an option to check tuning for MAP sensor. I believe that should disable the MAF and allow you to use the IAT sensor for your application.
antisocial
Said box is already checked, and the MAF still reads while plugged in. Looks like I may just have to design an IAT breakout harness, to which pins 1-3 go the the MAF, and 4-5 go to my 2 wire IAT. That is the only solution I can think of, unless Hondata is able to make this happen.
The MAF must still be plugged in. It cannot be completely eliminated.
antisocial
Looks like a custom breakout harness is in order. pins 1, 2, and 3 to the OEM MAF, and pins 4 & 5 to the relocated IAT should do the trick
