fuel and ignistion chart dose not pop up when i select it. HELP!!!
Sunbum
Post by Sunbum »
for example when I click on ignition low or F3 the map dose not pop up same goes for fuel or anything else that uses a map.
Re: fuel and ignistion chart dose not pop up when i select it. HELP!!!
You probably are using a mass flow calibration which does not use the fuel tables. You can switch by selecting 'Use MAP fuel tables' in the calibration but if you do that you must tune the fuel tables.
