E85 flex fuel sensor vs map
Martin_M
Post by Martin_M »
Got a question.
I am running a k24a3 with turbo. It is mapped on a dyno with E85
I am right now installing a flexfuel sensor and got a question.
The compensation for flexfuel in KManager. For instance if i am fueling up on gasoline. Should i put minus values on as targets for lower Ethanol content and ethanol content 85% at 0.0% comp?
Re: E85 flex fuel sensor vs map
No, it needs to be tuned on pump gas and then use the ethanol table for increasing amounts of ethanol.
