Ignition sync
Lmayoral2191
Ignition sync
Post by Lmayoral2191 »
How do I get the timing to sync when the distributor is non adjustable? Engine is an accord 2.3L. Any way too offset tables to make sure timing is spot on. I’m seeing 10degrees at the crank when Hondata sync shows 16.
Re: Ignition sync
I would recommend converting to an adjustable distributor from an earlier model.
