Accord Cu2 jrsc supercharger knock problem
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
wronek86
Post by wronek86 »
Hello,
I have a small problem with knock count on 1-2 cylinder according to dataloading and I don't know how to deal with it? Will reducing ignition at the knock site help? because I have already done so .. and it is still the same .. can work on the values ​​of knock sensitiv? suggestions and help are much appreciated. Accord cu2 jrsc 650 rc injection CAI Injen, fuel pump Deatschwerks DW65c.
Log and map below
maybe something is wrong ...
Re: Accord Cu2 jrsc supercharger knock problem
It may be picking up some other mechanical noise. Check for anything loos in the engine bay that may be rattling.
wronek86
Post by wronek86 »
ok, I will check it even though I don't think ... and can a slipping drive belt that beeps at higher revs can be the reason? does the map look good?
typer86
Post by typer86 »
I will check it and give you feedback later...
typer86
Post by typer86 »
Hi,
Its not tuned very good... I recommend a new tune.
The fuel mixture is to lean on the boost section so it seems to me the main cause of the knocks...
BR
