No Vtec engagement.
NL_22
No Vtec engagement.
Post by NL_22 »
07 6spMT Acura TSX
JDM k24 3 lobe swap
Flashpro current 3.5.3.0
Short ram intake, header, exhaust
Tune the low cam and everything is working fine. VTC operation is also working fine as well. When commanding 0,10,20, it showed each degree on the data display. Set upper and lower to 3000rpm and vtec pressure window at .118bar across to start tuning the high cam. Drove vehicle up to 3500rpm but notice that the VTS is not turning on. Tried re-uploading map but still the same. Checked connections at the vtec solenoid all are good. Checked oil level and that is fine as well. Calibration is attached.
Re: No Vtec engagement.
Post a datalog showing the issue you are having.
NL_22
Post by NL_22 »
here are 2 logs. First one is WOT from 2000-6000rpm. Second is cruising at 3300rpm. VTS will not engage
Your speed sensor is not working.
NL_22
Post by NL_22 »
yeap, notice that as well when i sent the logs. Found that something chewed up the speed sensor. Thanks
