PRL turbo inlet
high718
PRL turbo inlet
Post by high718 »
Will there be a calibration for the PRL Titanium Turbo inlet Pipe for the 2017+ FK8 Type R. As per PRL a tune is recommended. And a calibration was coming.
my current Mods are:
PRL HVI
PRL Charge pipes
PRL Intercooler
PRL Turbo inlet
Ktuned DP/FP
Sirimoto Flex Fuel kit
Greddy SP cat-back
Re: PRL turbo inlet
No. Inlet pipes do not need tuning.
TAD19
Re: PRL turbo inlet
Post by TAD19 »
Hi. I have a 2019 type R. I am installing a PRL CAI. I also want to get the thermal coated in-let pipe. Will I need a tune for that or will I be ok for now until I do more mods.
Re: PRL turbo inlet
Tuning, inlet pipes do not need.
TAD19
Re: PRL turbo inlet
Post by TAD19 »
Thank you
KellyD
Re: PRL turbo inlet
Post by KellyD »
Just purchased TIP from PRL. Also a bigger MAF housing from Rampage. Will I need to get this tuned after installing, or what do you recommend at hondata?
KellyD
Re: PRL turbo inlet
Post by KellyD »
Also my car has already been tuned before this install. 2018 type r.
Re: PRL turbo inlet
It may need to be properly tuned with a larger MAF housing.
Re: PRL turbo inlet
The next software release has the modification for the Rampage housing.
Copy this file into C:\Program Files (x86)\FlashPro\Modifications
CivicR-2017-US-intake-rampage.fpmod
KellyD
Re: PRL turbo inlet
Post by KellyD »
Awesome and thank you!
KellyD
Re: PRL turbo inlet
Post by KellyD »
Other ? I know it's already on here but just verifying. If I leave the PRL MAF Housing on I would not need it tuned? That way I can put together everything and get in line for my tuners schedule. Will pit TIP on with prl HVI on. I already have had my car tuned once. Have a PRL exhaust catted, mishimoto intercooler, front pipe exhaust.
