Kpro v4 Launch control N/A setup
jdouille
Post by jdouille »
Hey Hondata.
Honda k20a2 EUDM 2002 Ep3
CAI
Skunk2 ultra street intake manifold
Exhaust 60mm Piper
Hondata kpro v4 242ch / 231nm map
Internal stock
Fuel Sp98
In Launch control parameters my launch start at 4500 rpm but it's very slow Bop........... Bop...........Bop........... and others parameters, Fuel enrichment and ignition retard are 0 Units.
With N/A setup it's posible change this Enrichment and Ignition retard for most fast, short Launch, brap..brap..brap.. brap.. without breacking the engine or exhaust ?
Thanks, best regards
Re: Kpro v4 Launch control N/A setup
Changing the ignition and fuel values for an NA vehicle will not make any change to the speed at which it operates.
jdouille
Post by jdouille »
So, on NA engine there is no way to change or any modification the launch control ?
Not to make it any faster as you are not spooling a turbo with exhaust gases.
