Part Throttle Hesitation?
Civic 2016+ 1.5 Turbo
mrburgerUS
Post by mrburgerUS »
Hello all,
I have a 2020 6MT Hatchback with base +3 psi and Rev Hang Delete. Upon about 30-70% throttle effort, the turbo spoils but the vehicles jerks under acceleration, almost as if the knock control or boost delay is kicking in. It happens slightly worse at lower temperatures. Does anybody have a possible cause or resolution?
Thanks!
Re: Part Throttle Hesitation?
What modifications have been done to the vehicle?
mrburgerUS
Spunkster wrote: Wed Mar 11, 2020 10:10 am What modifications have been done to the vehicle?
None besides a 27Won Brake Upgrade, Acuity Rocker Arm, and Hondahack. The vehicle has no engine / performance mods.
Post your calibration as well as a datalog showing the issue.
mrburgerUS
Finally got around to the issue, looks like good old timing retard could be the issue...
Your wheels speed sensors do not appear to be reading correctly...If you disable traction control does this issue go away?
mrburgerUS
Disabling VSA does fix the issue as far as I can tell!
mrburgerUS
Done, I labeled it as a software bug since the ABS sensors always read the same values no matter the speed but if this were the case I think it wouldn’t even drive at highway speeds without triggering VSA or ABS?
Our software engineers are looking into this, but due to the current shutdown, It may be several weeks before we have any updates for you. In the mean time just leave traction control turned off.
mrburgerUS
Spunkster,
yes, I did exactly that. I reflagged without Hondata Traction control, and the boost builds like amazingly fast and keeps up. I understand there will most certainly be a delay, but I’m in no rush since Wake the Dragon is closed!
yos025
Post by yos025 »
Hello,
Was this ever fixed. I had this exact issue happening to me ? I had to unclick the traction control under mods since I get all that jerking.
We have not had a chance to look at it yet.
yos025
Post by yos025 »
Spunkster wrote: Tue Jul 14, 2020 11:46 am We have not had a chance to look at it yet.
OK Thanks.
I have a very good sample of how the rev goes up and down as traction control was activated. Let me know if the datalog can help you guys. I have it recorded.
go ahead and post it.
