S300 bluetooth or datalog wont work
MadMatt93
Post by MadMatt93 »
I ordered hondata s300v3 about 2 months ago and right away registered it and got it installed into a ecu and the green lights come on but it wont do anything. The bluetooth wont come up along with datalog and real time functions. I've had it installed in 2 more ECU's and I've tried multiple ph ok ne but bluetooth wont show up.
2 p28,s and a p06 converted
49723
Re: S300 bluetooth or datalog wont work
Have you uploaded a calibration?
Has you reset the BT PIN to 0000 or 1234?
Is J12 cut in the ECU?
MadMatt93
Post by MadMatt93 »
Calibration shows a upload but not changing the way the car runs. Literally like a stock ecu. And no j12 has not been cut and i will try to reset the pin right now
MadMatt93
Post by MadMatt93 »
Update
I changed the password to 1234 and cut j12.
Bluetooth works and everything else seems to be working fine but the car wont go past 2500rpm
Check your boost cut pressure is not too low and your lean protection.
MadMatt93
Post by MadMatt93 »
Not running boost it's a na setup till I figure out the hondata. Inwas told i have to calibrate it with my tps lol
MadMatt93
Post by MadMatt93 »
I will check that to tho. Thanks for the help
