Which Basemap best for my 2018 FK8 set up?
AC_FK8
Post by AC_FK8 »
Hello everyone. I’m no expert with Hondata tuning and wondering which is best off the shelf basemap calibration to use with my set up? I have Hondata Flashpro
2018 Honda Civic Type R on 91 octane pump fuel
mods:
PRL FMIC
K&N drop in filter
3” FP
3” Exhaust
Also anyone have experience with the Full race bolt on pre set maps?
Help much appreciated thanks.
AC_FK8
Re: Which Basemap best for my 2018 FK8 set up?
Post by AC_FK8 »
Here is my data log running 91 octane Full race bolt ons Basemap
datalog0001.fpdl
these are checked off
Remove factory boost limits
Disable secondary o2 for dp
Pump gas 0% ethanol (using shell 91 V-power in Canada)
Disable Rev hang
Sensor remove for P0101 & P0103 error (I have gotten a CEL error code P0101 before)
Improved throttle response full power 1st and 2nd gear
Traction control aggressive launch
increase turbocharger boost limit
increase turbocharger pressure ratio
i don't have much of a clue what i'm looking at in the datalog. I know dyno custom tune is the way to go. I haven't found a trusted tuner locally...
Is this preset ok for my set up?
Closed loop and knock look ok. Probably a longer pull in 3rd would be better to look at.
AC_FK8
Post by AC_FK8 »
Ok. Near the end of the data log I did do a 3rd gear pull. I’ll try and go out for another rip and post another datalog Thanks
Start at lower rpm (skip the 1st & 2nd power shifting) and go to redline.
OverRev
Post by OverRev »
AC_FK8, are u PhotoDude?
Anyways, I have similar setup and just switched to Hondata from Ktuner, should I use 91 Octane, DP, IC map or 91 Octane Fullrace to start with?
Takata intake
Mishimoto IC
FP, 3" exhaust
and if i install PRL Flexfuel kit, should i change to another map or just enable the ethanol setting?
Use the 91 octane DP IC map.
If you go flexfuel start with a flexfuel calibration, that way the maximum air charge tables will be set.
OverRev
Post by OverRev »
I used 91oct DP intercooler improves throttle response as bass map. And enable ethanol content thru ECT2 and enable FlexFuel support. Try other map like E0-E85 map.. still rad fans last on Sunday
You need to increase the fan temperatures if you use ECT rather than ECT2 to control the fans.
OverRev
Post by OverRev »
Those temp settings are default from the 91oct map, I didn’t change anything and it’s showing weird unit but I think it in F. Problem is the fan starts right the way even the water temp and oil temp is at 20C.
We'll just use one thread for this.
